webpage-location
Specifies the location of the Web pages used for authentication. These pages can either be hosted on the system or on an external Web server.
Syntax
webpage-location [advanced|external|internal]
Parameters
advanced
Uses Web pages for login, welcome, failure, and terms created and stored on the controller. Select advanced to use a custom-developed directory full of Web page content that can be copied in and out of the controller, service platform, or access point.
If selecting advanced, enable the webpage-auto-upload option to automatically launch the advanced pages to requesting clients upon association. For more information, see webpage-auto-upload.
external
Uses Web pages for login, welcome, failure, and terms located on an external server. Provide the URL for each of these pages.
internal
Uses Web pages for login, welcome, and failure that are automatically generated
nx9500-6C8809(config-captive-portal-test)#webpage-location external
nx9500-6C8809(config-captive-portal-test)#show context
captive-portal test
 access-time 35
 custom-auth info bob bob@examplecompany.com
 connection-mode https
 inactivity-timeout 750
 server host 172.16.10.9
 simultaneous-users 5
 terms-agreement
 use aaa-policy test
Related Commands
no
Resets or disables captive portal Web page settings
webpage
Configures a captive portal‘s Web page (acknowledgment, agreement, login, welcome, fail, no-service, and terms) settings
webpage-auto-upload
Enables automatic upload of advanced Web pages on a captive portal
